POD1_N Error
  • azcop
    • Sep 2025
    [Jamming] POD1_N Error
    Hello I am getting a POD1_N jam code and a H5-01 what is happening is when the paper races the fuse it doesn't actually enter the fuse it jams right at the fuse entrance and the paper folds like a fan. I tested the fuse in another copier and it worked fine. Any suggestions are appreciated
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: POD1_N Error
    Your message was a touch cryptic.
    You tried the fuser in another source, but did that second source use the same paper?
    • ZOOTECH
      Senior member of CRS
      • 3378
      Re: POD1_N Error
      Fuser drive gear/motor???
        • 23010
        Re: POD1_N Error
        Do you think you could tell us what model you're working on, or shall we guess? =^..^=
        • spanky
          • Sep 2012
          • 468
          Re: POD1_N Error
          Check the drive gear on the transfer belt.
          The inside of the gear where the pin sits will round out and the transfer belt will not turn.
          • Néri
            • Dec 2010
            • 7
            Re: POD1_N Error
            I have seen similar problems on MX-M550/620 and MX-3501/4501. In almost all cases, the problem was in the secondary transferbelt. The belt has a tendency to dry out and then starts to slip resulting in the paper to fold before it enters the fuser.
            • Josh93
              • Jul 2014
              • 47
              Re: POD1_N Error
              Also run a sensor check, and make sure your POD1_N and POD2_N sensors flick on and off, don't know what model yours is, but had a sensor lever snap the other day and cause something similar. (Sim 30 for the sensors)
              • MHeon71
                • Oct 2008
                • 490
                Re: POD1_N Error
                I usually see it as the primary transfer blade flipped, but it could be one of the above. A model number would be helpful.
                • jp74msj55
                  • Oct 2014
                  • 152
                  Re: POD1_N Error
                  Sounds like a bad sensor, had this code quite frequently. Usually sensor with arm sticking up below fuser. Usually checks good in sim code but has been my fix recently.
                  • coopers1305
                    • Nov 2014
                    • 49
                    Re: POD1_N Error
                    Try one of these....
                    Turn on Misfeed Disable Sim:7-1. If copies make it though its a sensor, and if not its mechanical. [Sensors]
                    Next check gear on primary transfer belt. [Gear stripped]
                    Next change 2nd transfer unit. [Bad belt] I wouldn't rebuilt it.
                    And if none of that works then try changing the registration roller unit.
                    Good luck.
                    • bonnie750
                      • 302
                      Re: POD1_N Error
                      if this is a mxm620 series machine it is going to be the hot roller gear. broken drive peg
                      • mojorolla
                        The Wolf
                        • 2639
                        Re: POD1_N Error
                        I predict a C402 with a flipped IT blade...
