copy quality problm
  • abbas
    • 39
    [CQ] copy quality problm
    hi dear friends. i have a copy quality issue model sharp mx-3610 printer and i tried to replace developper color or high voltage board also & adjust procon halfton printer color callibration not yet solve the problm. pls chk the attachment print & give me some technical quarees .....
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: copy quality problm
    And what is the problem? It would help if you marked where the faults are and what direction the paper travelled.
      • 23009
      I'm going to make a WAG that there isn't any cyan on that page. Maybe you should look into that? =^..^=
      • abbas
        • 39
        Copy quality is very late copy or print or not mixing proper color. Ones i take print out different color coming.
        • bilyahn
          • Dec 2006
          • 1470
          Print out a sim 64-5 test pattern and scan that for us. Might help us a little more than the attached scan. Just use the default setting and you will get a color and monochrome test print.
          Good luck.
          Bil
          • Jhonjon
            • Sep 2013
            • 208
            Try to test single color CYM to know what color is having a problem. It is not mixing properly that's' why the copies or print didn't' match the original...
