Hi, I have the error code L4-02 in a Sharp ARM-450. I executed the sim 25-1 as the service manual indicates and the drum motor works fine. Any suggestions to remove this error???
L4-02 in Sharp ARM-450
OMD-227
Drum Motor Lock. Seen this many, many times.
Remove the process unit, remove the drum & check the waste toner auger & gear assy. You will probably find this is seized or broken due to excessive drum cleaning. When changing the drum & developer, you must reset the rotation counters as well as the drum/dev counters. Otherwise, there is excessive over-toning, leading to waste toner filling the toner cartridge waste area too quickly & therefore leading to waste toner auger assy blocking up.
You will probably need a new process unit as the auger drive gear breaks off the frame.
There is new firmware for this problem. Make sure it is updated. Once this is done, it will not happen again. Trust me..... seen it way too many times. All firmware updated machines run perfectly. The rotation counters need to be reset to prevent the overtoning in the first place. -
mammm23
Do you know which is the correct version of Firmware??
where can I find it??
What is the process to upgrade it??
Thanks a lot for helpComment
01.05.05 Tiger Firmware O00.zip
Main - mJ.10; Boot - m5.03A; PCU - 9.04; Scn - 06.04) firmware AR-M350/M450/M350U/M450U/M350N/M450N.
Sim 22-05 Definition of version ROM and serial number of the device
Firmware series AR-M350 and AR-M450 it is updated through parallel port
The device by means of the Parallel cable (Centronics) and programs
FCOPY.EXE
Note: Update the first Boot Rom, then Main Rom.
Procedure is connected with switching (jp) of crosspieces on a payment
Has forgotten to tell, that
1. Update Firmware - process not idle time. You do it at own risk.
2. Try before Update Firmware, to keep an old file.
3. Version O00.zip - for Russia but English language is present.
Answered here are absolutely right.
I had a case. After maintenance service. The clearing edge was turned out also the same result. At what the copy was absolutely normal.Attached FilesLast edited by vlad_; 07-31-2008, 07:08 AM.Comment
Wazza is right. Start there. Most often it's a locked up cleaning unit causing it.
But there is one other possibility. On a few occasions I've had the HVT cables shorting to the main drive assembly. I imagine you coud try to order separate HVT cables, but I've always just replaced the main drive assembly. It's a major pain to change. If it's your first time it will take you over an hour to get the thing out and on the floor. The main drive assy is good for ~1M copies before it starts to seize. If you're getting close to that don't hesitate to replace the assy. =^..^=If you'd like a serious answer to your request:
Re: L4-02 in Sharp ARM-450
The above are all correct, but I have corrected several by replacing DV Drive spring, per bulletin MFP-TB-290. If your DV ever spilled and it is piled up behind the machine around the Main drive unit, I would think it is safe to say that you will need a drive unit.
As far as broken waste toner gear on process unit, I have only replaced the 3 gears on the back and not the whole process unit.Comment
