e-s655 wierd problem..help!
  • mixtape7
    • Jul 2025
    [Dead] e-s655 wierd problem..help!
    Hi guys~I have a problem with es655.
    This 655(called A)is no displayed on Lcd,but upper right corner red light is on and yellow light flashes,so I take another 655's(called B) SYS and HDD to replace.I change the HDD first,not working(even 3c mode),then I replace SYS,still the same condition.Then I put both 655A and 655B's SYS&HDD on 655B,it turns the same as 655A(red light's on & no displayed).....
    I want to make sure those two HDDs are bad or not,I put them on my 455(called A),both of them are not working(red light's on & no displayed),so i change back the original 455's HDD,it becomes red light on and no displayed...I replace another 455's(called B)SYS&HDD on 455A,the result is the same...
    Can somebody help me ...I have two dead 455 and two dead 655 ....
    Sent from my iPad using Tapatalk
  • ARMAN.MZ
    • Sep 2016
    • 100
    Re: e-s655 wierd problem..help!
    check wires
    check power board
    there is a cover in right side of 655 (lan and usb connector) check this cover because back side this cover wires came to display
    Telegram ID : @armanmahzun
      • 23007
      http://www.copytechnet.com/forums/ko...tml#post537919
      • jirehjawo
        Did you try replacing the Mobo?
        Sent from my SM-G920I using Tapatalk
