Toshiba ES 2550C color calibration unstable
  • davidbolden
    • Oct 2016
    • 2
    [CQ] Toshiba ES 2550C color calibration unstable
    The color registration is off in the paper feed direction. I have tried adjustment mode [05]. Select code [4719] and the problem persists.
    I have cleaned the copier thoroughly and it only has 180K total prints. Customer is using OEM toners. No error codes. Just crummy registration, which is not consistent.
    Any assistance appreciated
  • Luther
    • May 2006
    • 682
    Re: Toshiba ES 2550C color calibration unstable
    you could try color registration under the admin tab in user tools, but my bet is the transfer belt bushings are starting to bind up, remove the belt assembly and remove the 2 spring loaded plastic pieces that hold the big roller on the end of the belt that are closest to the cleaning assembly.
      • 22999
      Have you looked at the patches on the primary transfer belt? Any CA00 or CE40's? =^..^=
