anyone got an old e350/450 HDD "working and ready to use" they would sell?
  • CCS
    • 266
    I know some of you have scrap piles of old machines like me, anyone have an e350/450 HDD to sell that is good and needs no programming-plug in ready
    I have some E352/453 series, but can you use that HDD and simply just re-flash e450 f/w on it without the e450 restore jig ?
  • Ropariva
    • Mar 2016
    • 703
    Re: anyone got an old e350/450 HDD "working and ready to use" they would sell?
    As long as the HDD is under 80gb any standard drive will do. You will need to reload the FW anyway as part of it is loaded to the HDD. Just swapping a working HDD into your machine may give you mis matched FW. May also work with a drive up to 160gb but those older machines were a bit fussy about the drive size.
    Good luck.
      • 23010
      Ropariva is correct. You cannot pre-load the HDD and expect it to work. There is a registry file on the MFP that is written during the firmware writing process, to help the machine locate the firmware files. Since each of these registries is unique, if you had two fully functional machines of the same model side-by-side, then swapped the HDD's, neither would work because neither could find it's firmware files.
      Did I explain that clearly? =^..^=
      • CCS
        • 266
        Yes, I understand whats being said, But I have done it with success before.
        Last year I had another e450 HDD crash with the rotating screen you know, I simply robbed another HDD off of one of our scrap machines and plugged it in, did nothing else, machine worked fine, but I do know they both had same final vs. of f/w on them to begin with.
        I have also swapped from one e452 to another e452 same HDD both machines, works fine, again both were known to have same vs. f/w though.
        I can reload f/w no problem, I was just looking to see if someone had one since all these machines are mostly out of service in spare parts piles now and easy to pull one off
        • MUMMIM
          • Jan 2008
          • 125
          Hi guy
          needn't firmware, it is so easy if who you have a hdd e350 - 450-352-452 -283- 280... (ATA HDD) which can be formated
          replace old hdd on your machine,
          C+3 power on -- press 3 - star power off
          0+8 power on -- 690 enter. waiting it show " reboot the marching " power of . power on
          it is work .
          Note: It can't use print and scan functions , it is only photo function . if you like print and scan functions you must update new firmware .
          it only use for e230-280-350-450 (e xx0 ) , don't use with e282-283 - 352-353 ( xx2-xx3) , you must update firmware with that series because all data is put in HDD.
          good luck to you
          MM
