You can order a new scanner logic board, or send in your board to Hytec and have it initialized and proper firmware loaded. Do you have a board repair service available in your country?
In the future, keep in mind that the only difference is the scanner firmware. If you de-select the scanner firmware update, you can use either yellow dot or red dot. =^..^=
[QUOTE=blackcat4866;590164]You can order a new scanner logic board, or send in your board to Hytec and have it initialized and proper firmware loaded. Do you have a board repair service available in your country?
In the future, keep in mind that the only difference is the scanner firmware. If you de-select the scanner firmware update, you can use either yellow dot or red dot. =^..^=[/QUOTE
What if you don't have access to Edoc in the case of Xerox repairs ?
I think that your comment is a non-sequitur, having absolutely nothing to do with ARMAN's question.
I humbly suggest that you start your own thread in the Xerox forum. =^..^=
