toshiba 456 f350
  • ARMAN.MZ
    • Sep 2016
    • 100
    [Dead] toshiba 456 f350
    i have toshiba 456 with yellow dot
    upgrade frimware with red dot
    error f350
    upgrade with yellow frimware FAILED01
    .how to fix?
    Telegram ID : @armanmahzun
    • 23010
    Re: toshiba 456 f350
    You can order a new scanner logic board, or send in your board to Hytec and have it initialized and proper firmware loaded. Do you have a board repair service available in your country?
    In the future, keep in mind that the only difference is the scanner firmware. If you de-select the scanner firmware update, you can use either yellow dot or red dot. =^..^=
    • yomba
      • Jul 2012
      • 37
      [QUOTE=blackcat4866;590164]You can order a new scanner logic board, or send in your board to Hytec and have it initialized and proper firmware loaded. Do you have a board repair service available in your country?
      In the future, keep in mind that the only difference is the scanner firmware. If you de-select the scanner firmware update, you can use either yellow dot or red dot. =^..^=[/QUOTE
      What if you don't have access to Edoc in the case of Xerox repairs ?
        • 23010
        I think that your comment is a non-sequitur, having absolutely nothing to do with ARMAN's question.
        I humbly suggest that you start your own thread in the Xerox forum. =^..^=
        • didi2005
          • May 2011
          • 401
          Use jig to update firmware~~~
