Toshiba e 256 Registration
  • copyguy69
    • Feb 2016
    • 94
    Does anyone know the service code to adjust the registration off the glass not the ADF? Thanks in advance copyguy69
    • 23010
    Re: Toshiba e 256 Registration
    Yes there is. Each tray is adjustable separately. =^..^=
    • copyguy69
      • Feb 2016
      • 94
      Thanks blackcat for the response. Looking for the top tray. Could you point me toward the 08 code?
      copyguy69
        • 23010
        I could, but sadly I don't read manuals for those that can read for themselves. =^..^=
        • copyguy69
          • Feb 2016
          • 94
          Thank I guess. Just thought if you knew it off the top of your head you could share. I have the manual and fortunately can read. Again thanks - maybe
          copyguy69
            • 23010
            Look in the adjustments section. When doing image adjustments you always want to start at the beginning:
            print ratio main scan
            print write start main scan
            print ratio sub scan
            print write start sub scan
            scan ratio main scan
            scan write start main scan
            scan ratio sub scan
            scan write start sub scan
            scan lead edge void
            scan side edge void
            scan trail void
            DF write start main scan
            DF write start subscan
            It takes about an hour and probably will never need to be done again, once done properly. =^..^=
            • ncbabak
              • Apr 2014
              • 43
              Hi
              Code in mode 05
              Scanner related (a) Reproduction ratio of primary scanning direction adjustment => 4000
              (b) Image location of primary scanning direction => 3030
              (c) Reproduction ratio of secondary scanning => 3032
              direction
              (d) Image location of secondary scanning direction => 3031
              (e) Top margin => 4050
              (f) Left margin => 4051
              (g) Right margin => 4052
              (h) Bottom margin => 4053
