EStudio 5540C error C4e0
  • digicor
    • Jul 2008
    • 1153
    I have done the fuser bracket upgrade, replaced all the fuser rollers,belt.. and It will print at first, the the code pops up, then it wont re set, fuser reads 0 and 0 in 2002 service mode
    is there something else i can re set or set? please advise
  • gliderider
    • May 2015
    • 131
    Re: EStudio 5540C error C4e0
    Have you followed the trouble shooting process in the Service Manual yet for that error? It's pretty straight forward. Also the flag for the contact/release sensor ( it looks like a bowtie) can break and cause the C4E0 error also.
    Andrew
    • digicor
      • Jul 2008
      • 1153
      ive ordered a clutch and a new sensor, the flag looks to be intact, thank you
        • 22999
        Bowtie intact is good ... white colored is better. I've seen them turn brown and not trigger the sensor properly. Also check that the satellite roller bushings are intact. If the bushings are disintegrating or bearings seized the heat belt will be slack, giving you the same code. Same effect is the foam roller bushings have disintegrated. =^..^=
        • digicor
          • Jul 2008
          • 1153
          Okay it seems to have been the the fuser clutch 6LJ08815000 CLUCH-33C-8-CCW-FUS
          this seems to have been the problem client has ran several jobs and no code C4e0 is solved
          I replaced the service bulletin bracket upgrades / no fix it, i replace the fuser rollers and belt, no fix it/ so we looked into the drive section and found a clutch in the motor section turns the pressure roller position trip flag
          thanks for all your help
