e-Studio 457, jam in fuser...
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys,
    So, we went out to this machine and put a new Exit Sensor in it, didn't work. Then swapped the small harness that goes from the sensor to the connector on rear of the fuser... same thing. We ended up having to swap the fuser out but I'd like to get it running... just shows a permanent jam. Could there be a problem with the main fuser connector in some way...?? Weird...
    OC
    • 23007
    Re: e-Studio 457, jam in fuser...
    Jam code? =^..^=
    • Oystercopy
      • Oct 2009
      • 623
      Thanks for the reply Black Cat, and I can get that code for you. However it is definitely the fuser sensor which there is only one of them in that is causing it... that's why replacing the fuser fixed the problem I think??
        • 23007
        So the replacement fuser resolved the issue... could be:
        wrong sensor
        Plastic frame closure busted out so there is no fuser pressure
        inlet guide out of position or gone
        Heat roller ring gear broken
        Damaged modular fuser connector
        maybe it's just the wrong fuser that somebody else installed? All the Loire, LoireX, and Loire2X fusers look similar, but there are differences electrically.
        All my resources are organized by jam code. Without a jam code I have to rely on my diminishing memory.
        • Oystercopy
          • Oct 2009
          • 623
          OK, the jam code the machine is showing is E030, paper remaining the transport area. As stated however, replacing the Fuser solved the problem out in the field. This is the same exact issue that the customer's machine in the field had, and the machine had been out there working for several years without issue. We took the fuser from THIS machine out to the customer and it fixed the issue, so now I'm trying to troubleshoot this fuser to find out what went wrong with it. Again, new Sensor and new harness that goes to the sensor have been replaced. Whatever else that can be added would be great...
          OC
          • Oystercopy
            • Oct 2009
            • 623
            [QUOTE=blackcat4866;1218740]So the replacement fuser resolved the issue... could be:
            wrong sensor
            Put TWO new, OEM sensors in the unit, same thing. Yes, they were the correct ones for this machine (although, I think they'd be all the same in every fuser of this series machine?)
            All three of the above could not be possible, because the jam shows on POWER ON and no motors/gears are trying to turn at that point, only a jam code. No paper movement.
            I guess this is possible, but in all these hundreds of frames, have you ever seen one damaged/not making connection? I haven't, that's why I ask...
            Already answered this question in another post, but both fusers in question were from working e-Studio 457s
              • 23007
              Ok. You're right. It's none of those things. So don't try anything.
              Do your remember Eeyore?: "It'll never work."
              You're right, it won't work because you won't try. =^..^=
              • tsbservice
                Field tech
                • 8007
                Power on jam from my experience always ended with some bad sensor. I replaced a few exit sensors on older models. I'm really puzzled that your problem isn't sensor/harness.
                • Oystercopy
                  • Oct 2009
                  • 623
                  [ATTACH=CONFIG]44732[/ATTACH]
                  Just trying to use logic dude.. sorry if you're offended! The only plausible option left is the main connector on the fuser. Or a bad board.
                  • Oystercopy
                    • Oct 2009
                    • 623
                    Me too, but I'm going to try everything else before giving up.
                    DEFINITELY why I have been moving away from Toshiba for years now... what a piece of crap! (and I've been working on them over 30 years...)
                    OC
                    • Oystercopy
                      • Oct 2009
                      • 623
                      Just following up on this, but it ended up being bad pins on the modular connector on the fuser.. hard to tell at first glance until I looked closely at all the pins, and some of them were bent/smashed. Ordered a new connector and that did the trick!
                      OC
                        • 23007
                        wrong sensor
                        Good catch. =^..^=
                        • tsbservice
                          Field tech
                          • 8007
                          Good catch. =^..^=
                          Yeah, our friend OC may also consider wearing glasses if not. On side note, my eyes just started weakening. It's difficult to see small details and definitely need soms good light
                          OC, thanks for the feedback and next time be less grumpy, dude
                          • Oystercopy
                            • Oct 2009
                            • 623
                            Didn't think I was being grumpy, and here's the proof:
                            Look guys, I wasn't trying to bypass the connector as being the issue, only wanted to know your experience with that issue? It took me over a month to go back to the machine (one man show, you know?) so things could have been dropped in the interim. I'm human, as are you. I could have just as well not posted what I did to fix the problem, especially if it was going to result in snarky, useless comments that help no one.
                            OC
