Toshiba 3005AC Rainbow running Lengthwise on certain halftones
  • Rusty.Harris
    • Jan 2021
    • 630
    Originally posted by Munter
    I'm not familiar with this term. When you say "facing roller" am I correct in assuming you are talking about the roller inside the Tx belt that the secondary Tx roller indirectly presses against?
    Also, could you provide that ANSI A file for A4 paper, please?
    Toshiba uses that term. The 2nd transfer roller, is the one that is mounted on the ADU door you open on the right side of the machine.
    They also call the roller inside the transfer belt a transfer roller, but they use the term 2nd transfer facing roller, I guess because it faces
    the transfer roller.
    • djbass
      • May 2008
      • 165
      The manuals often refer to the ones inside the transfer belt as TR1 rollers and the one on the ADU door as TR2 roller.
      No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
      • Pirate1936
        • Oct 2019
        • 9
        Have had this many times and it has always been the colour drums. Replacing the transfer belt has improved it for a while but have had to do the drums eventually. as per your samples , it is only really obvious when client printing halftones
          • 23007
          #19
          Solved in post #11: https://www.copytechnet.com/forum/te...78#post1585478
