Please wait message on toshiba e studio 207
  • malithdias
    • Jan 2021
    • 2
    [Dead] Please wait message on toshiba e studio 207
    Dear All ,
    My toshiba e studio 207 appering only please wait . I try to reset useing 1+3+* but still same issue .
    Re: Please wait message on toshiba e studio 207
    Originally posted by malithdias
    Dear All ,
    check HDD and reload firmware
    • tsbservice
      Field tech
      • 8064
      Do you have GA-1200 scan kit?
      If Yes remove it and try machine, if it comes to Ready format CF card.
        • 23010
        An open heater lamp could cause that. =^..^=
        • malithdias
          • Jan 2021
          • 2
          Hi , thanks phil .. 207 have ep-rom only .no hdd . Any way I will check firmware .
          • Rusty.Harris
            • Jan 2021
            • 639
            Fuser
            I don't have any 207's, but since they share most of the parts of the 455/56/57 series, makes sure
            if the fuser has been rebuilt, that the connections and lamps were put back in the proper place.
            I've had techs switch the connections around, and even if they have changed the lamps to make it
            "impossible" to do that, Murphy's Law ya know...
            • riyadh hossainbd
              • Dec 2015
              • 239
              Cause are below
              1. CIS unit
              2.20 pin flexible flat cable
              3.SRAM
              4.logic board
