C471 AFTER replacing the belt holder!
  • Rusty.Harris
    • Jan 2021
    • 639
    Any TABS techs still having C471 issues with the 85 series b&w/color machines?
    I've had enough of this! I'm sure Toshiba will pull my post to their bulletin board, but I had to rant on
    there Friday morning.
    Ok, we were told the belt holder is the issue. Well, we just got a fuser back, that had the belt holder
    replaced after being in the field 3 days. C-471. Fuse is OPEN. All procedures were followed as to the
    handling of the belt holder, oil, inserting the fuser belt etc. NO stress was placed on the belt holder
    what so ever.
    WHEN will this be addressed? Dealers are spending a LOT of money trying to keep the 8508/18 machines
    running, when the slower speed machines are NOT having as many failures. This machine has ALL software
    and updates included. AC line checks good & is on a surge protector!
    • 23010
    Re: C471 AFTER replacing the belt holder!
    You wouldn't happen to mean 6506ACT/6516ACT/8508A/8518A MFP's, would you?
    Have a look at this:
    ES 7516AC error C471
    • Rusty.Harris
      • Jan 2021
      • 639
      Man, I've tried every mod Toshiba has made, tried some of my own, still no go. Talked with ATSG guys out in CA,
      DSM...nothing seems to help. Poor design...set some polices to try the fan speed and even lower fuser temperatures
      to see if that helps.
        • 23010
        You're welcome. =^..^=
        • Rusty.Harris
          • Jan 2021
          • 639
          I made the policy changes on the ECC server for all of the machines for the fan speed.
          I've got two "test mules" close to the office I use as guinea pigs for other things. I've
          set those with the 08 codes for the fuser temperature. If I don't get any negative feedback,
          I'm pushing it to the rest of our machines.
          I'm sick of these c71 and other fuser issues with this series.
          I jinxed it back when I went to the first school in Chicago on the EBN. When they showed us
          the 5506/08 machine, we all said it looked like a 5540/60, but the op panel arm was removed.
          I just had to taunt "Murphy" by saying fantastic! We won't have any problems with this machine!
          Little did I know...the fuser was the major change and THAT was what we have all the issues with.
          Thanks again for the codes. I'll keep you posted how they work out.
          • Rusty.Harris
            • Jan 2021
            • 639
            So far...so good.
            • marn1980
              • Jun 2021
              • 3
              C471 Need to clear error code in service mode. 08-2002. If can't,machine still got error.Need to replace thermometer(inside the IH coil) or replace IH coil hold unit.
              • barber782
                • Aug 2011
                • 286
                Toshiba have a new holder for the thermistor and different fuser oil. Pretty much all the C471 errors i get are repaired by replacing the thermistor, holder and applying new oil. Also Im sure there is a firmware that addresses this error code.
                • Rusty.Harris
                  • Jan 2021
                  • 639
                  Here's what we've been doing, since around mid April...it has made a DRAMATIC decrease in ripped fusers, C471's.
                  Using Shin-Etsu oil instead of the stock oil, doubling the amount.
                  Installing all mods (obviously), setting the energy save to 30 minutes, super sleep to 60 minutes (most of these
                  we have are schools...they have a lot of idle time)
                  Changing the following 08 codes
                  08-2010-0 =9
                  08-2010-2 =9
                  08-2010-10=11
                  08-2386 =2
                  This basically sets the fuser operating tempertures to that of the 5506/18 series. Most of our machines don't get
                  pushed volume wise. We've not had ANY calls for print rubbing off, under temp errors or "wait warming up" messages.
                  If we were to encounter that, I'd just increase the 08 codes for temperature, to that of the next speed faster machines.
                  The big test, for the oil evaporating, will come this fall, after the machines have pretty much sat idle all summer.
                  If we don't get a lot of ripped up fuser belts, the oil must be stable enough and not leak as bad as the stock oil.
                  On the plus side, given that oil from TABS is around 30-50 dollars a bottle, if you order it from them separately,
                  I'm sitting on about 4,000 dollars worth of oil! Time to load up the truck & to head to Beverly (Hills if you know the
                  tv show I'm talking about LOL)
                  • Rusty.Harris
                    • Jan 2021
                    • 639
                    Gee, guess what TABS wants us to do now?
                    Just noticed end of July, TBS released TSB-2016 and guess what they want us to do now?
                    LOWER the fuser temperatures of the 85/75 series high speed machines because they think
                    the operating temperature is too close to the pop temperature of the thermal fuse. YA THINK?
                    New 1600 firmware is suppose to have a bunch of other settings along with the ones blackcat
                    provided. So far, since we changed all of those settings in March, our service calls for 471's have
                    DROPPED big time!
                      • 23010
                      Congratulations! The machines giving me codes have stayed silent too. I did a PM on one of the 8508A's and its doing fine. Thanks for posting back. =^..^=
                      • Rusty.Harris
                        • Jan 2021
                        • 639
                        Something else I've noticed. Along with the fuser codes, switching from the stock thimble full of oil TABS gives you with the belt or fuser
                        kit, switching to the Shin-Etzu oil & doubling the amount has DRASTICALLY cut the number of ripped up belts we get back, because the
                        oil dries up. Most are coming back just flat worn our, or custome damaged, and when you rebuild them, the wick isn't ripped to shreads
                        because the oil dried up.
                        Shame it takes the techs in the field, to fix what the engineers didn't figure out, but, I've been doing that since I got into this.
                        • tsbservice
                          Field tech
                          • 8076
                          Well done! I feel no shame. Just be proud of doing your best. America support engineers with dealerships help being TABS or later KMBS SSD support team are doing great jobs in my experience.
                          • Logged-on
                            • Sep 2010
                            • 197
                            I questioned my service manager just before he resigned last weekend, why doesn't Toshiba just release a thermostat that is rated 10 degrees higher? Since they didn't seem to think the temperatures are at fault.
                            • Rusty.Harris
                              • Jan 2021
                              • 639
                              I asked a couple of the hotline guys that last year that know me....they said well, ummm...ahhhh...
