5005AC passwords
    • 23009
    Re: 5005AC passwords
    Originally posted by tnrtt
    ... Thanks for the non smart ass answer.
    Sorry, I can't be a smart ass all the time. =^..^=
    • tnrtt
      • 156
      That was a dig at MUMMIN "there are all in service manual, guy." comment. If YOU don't know, he sure as Hell doesn't.
      • Rusty.Harris
        • Jan 2021
        • 633
        Decommission the machine. 08-8615, then once finished (not connected to the network, it will
        say it failed, but will work). Reboot into 08 mode again, 08-8616, reboot.
        This will "wipe" everything and set it back to factory, without having to reload the software.
        All passwords set back to default, any customer data wiped.
        • Vincent128
          • Sep 2015
          • 349
          #19
          Will this also wipe out PM counters and IQC Information ?
          • Rusty.Harris
            • Jan 2021
            • 633
            #20
            Nope, leaves them alone, just "user" data (address book, emails, shortcuts, customized screens etc)
              • 23009
              #21
              How would you do this if you don't know the service password? =^..^=
              • Rusty.Harris
                • Jan 2021
                • 633
                #22
                Well, that's what happens, when you respond to a thread, before you are really awake, or have someone
                yacking at you while you are posting LOL.
                • tnrtt
                  • 156
                  #23
                  Took a system board from a junk machine. The password is on there. If anybody else runs in to the same thing, you need the system pcb. No replaceable SRAM.
                    • 8214
                    #24
                    ... hopefully you will not run into any SED-HDD issues because the Serial #s will not match. Best to have a formatted SED-HDD and the firmware handy.
                    • tnrtt
                      • 156
                      #25
                      As a matter of routine I formatted the HD, reloaded firmware, initialized and put in the sn.
                      • Vincent128
                        • Sep 2015
                        • 349
                        #26
                        So....Bare with me its been Monday for 3 days now.
                        IF Service password and Admin password are Unknown then it will require a sys board swap. Guessing you can't fix the key mis-match and need to reformat HDD
                        However IF at least one of the passwords are known, then there are ways to reset the other per the instructions in the service and or user documentation.
                          • 23009
                          #27
                          Correct.
                          • riyadh hossainbd
                            • Dec 2015
                            • 239
                            #28
                            There are a removable ic in system board
                            "R45V200A"
                            Change it
                            H + S mode >password keep blank >enter >reload firmware
                            It will be ok
