toshiba 5055c
  • billmcwho
    • Jul 2020
    • 22
    toshiba 5055c
    rebuilding a fuser and there is a woven nylon pad that is really mangled. has anyone rebuilt one of these and just removed the pad?
    • 23007
    Re: toshiba 5055c
    It won't run without it. It's a teflon sheet, that has a special oil. If you leave it off (and I've seen it done) the fuser sleeve will last less than a week.
    You'll notice in the kit a packet of screws? They are slightly larger that the original screws. The original screws tend to back out and let go of the teflon sheet. Then thats what you get.
    • Vincent128
      • Sep 2015
      • 349
      Re: toshiba 5055c
      What the Cat said
      Also, I would really read and re-read the instructions before rebuilding one of these - lots of little things to remove and lay out and not break and there is...a feel to refilling the oil. Search the forum, the console color box is very similar in design.
      Use EVERY drop of the kit's oil and don't spill any or allow it to leak out during reassembly. With the hot roller and heating core out of it's holders and in your paws, it's quite fragile and you don't want to have to re-build one of these twice...
      • Rusty.Harris
        • Jan 2021
        • 629
        Re: toshiba 5055c
        And make sure when you replace that pad, you get it in there EXACTLY straight, no bends or ripples. And make sure those
        replacement screws are used and TIGHT.
        • Toshcopierfixer
          • Jan 2016
          • 5
          Re: toshiba 5055c
          DO YOUR SELF A FAVOR...I have rebuilt them for years GO BUY SOME LOCK TIGHT put just a little tiny bit on the screws for the pad....NONE of my screws back out!!!
