I have a e2515AC at a busy earth/ bark mulch supply company.
There is quite a bit of dust floating around that has penetrated the copier.
I do occasionally visit the copier and have attempted to pre-emptively blow out the dust.
I am getting squeaks from the Paper Exit/Reverse section. There is no finisher installed.
I can see the plastic gears are discoloured but not worn. After two years since install, the copier has 125k click on it.
Image quality is good. Everything works well but there is an annoying squeak coming from the Exit section. The office workers sit right next to the copier.
What lubricants should I use particularly around the metal bearings/ bushings?
