toshiba 3508 no boot / powerup failure
  • lazymangr
    • Feb 2017
    • 115
    [Dead] toshiba 3508 no boot / powerup failure
    hello! just got a call from client that on powerup the machine goes to 2/9 booting steps then reboots, again 2/9 and reboot. cannot acess any mode for update, 08 menu etc. swapped memory ram and hdd but no help. any clues / leads?
  • Vincent128
    • Sep 2015
    • 349
    Re: toshiba 3508 no boot / powerup failure
    I would say to start with the electrical troubleshooting guide ...but Toshiba seems to not have one for that series, not one I can find anyway.
    But I would start by doing something similar to the previous guides...unplug just about everything and try to isolate.
    • mojorolla
      The Wolf
      • 2609
      Get out the volt meter and start pinning out the power supply.
      This is most likely your cause.
      • Rusty.Harris
        • Jan 2021
        • 630
        Not "posting" past the system board. Can you get into FS mode?
        If so, can you get into HS mode? If not, something scrambled handing off
        from system to logic.
        • clint@clintsimonsen.com
          • 124
          Try with the doors open, drum/ dev removed, and fuser removed.
          Main charge short will cause similar.
          But in the end high chances of Sys board
          Sent from my Nokia 8.3 5G using Tapatalk
          • lazymangr
            • Feb 2017
            • 115
            thanks for the aswers. i have a same model donor machine in service. swapped power supply and HV board, tried with all consumables out of the machine ( iu + fuser) and all doors open. nothing changed. i cant get neither hs or fs mode. now i will swap boards and will see from there. thanks!
            • Vincent128
              • Sep 2015
              • 349
              Have you looked at the power from the wall and the power cord ?
              • riyadh hossainbd
                • Dec 2015
                • 239
                Its time to change system board otherwise you need to update firmware with "ROM Recovery" . Few days ago i solved this kind of problem
                • tsbservice
                  Field tech
                  • 8011
                  In fact most of my such no boot/dead machine cases are due to faulty main board. Unlike old days when power supply boards failed a lot. I mean 90% and up.
                  • mojorolla
                    The Wolf
                    • 2609
                    I guess I am biased as in 2 years on Toshiba, both my non-booting machines have been power supply failures. But I cant wait for my first main board failure....yay!
                    • tsbservice
                      Field tech
                      • 8011
                      I must apologies and admit I no longer work on Toshy more than 10 years. All the best to you and let your sail with this brand will be calm.
                      • lazymangr
                        • Feb 2017
                        • 115
                        coming back again with solution. unfortunately the sys board is fried. thanks all for the help!
