3511 Periodic Maintenance Code
  • CopyDawg
    • Dec 2008
    • 74
    Does anyone know how to clear this and make the code go away?
    Thanks.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Do the maint, then run code 08-252
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • techman
      • Dec 2007
      • 49
      Hold down start and 6 while turning on the machine the press 2 and start this will bring you to the maintenance list and it will help you locate what needs to be replaced or you can also clear the counters in this same mode.
      • fireater
        Repair God? not quite
        • Apr 2006
        • 253
        both methods are right.... but techman is very right... do you PM's ..... these machines need there PM's done promptly and use the kits... dont scrimp on a few bux because you think it will be ok without that small part you think wont matter... i used to have 150 of these to work on ... if you do the pm's and use the kits ... and USE 281C colour dev .... they arent that bad
        I fix copiers ...Well Sorta
