4505ac
  • tnrtt
    • 156
    4505ac
    Getting a white strip 2 and 3/8 in from trail edge on 2nd side. 1/2 in wide. Print isn't affected, no crease. any ideas?
    This gallery has 1 photos.
  • djbass
    • May 2008
    • 168
    I can't really identify a problem from the supplied picture, I can only assume the arrows are supposed to be pointing at something, but I don't see the problem mentioned.
    No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
    • tecnomarco
      • Jul 2011
      • 214
      in fact it is not possible to understand the problem from the attached prints from the positioning of the arrows I assume it is a lighter stripe ..... if that is the problem it could be the dirty laser pass the blue rod to clean it
      • Vincent128
        • Sep 2015
        • 350
        Print some internal test patterns or Mr. Blackcats test file - we know what those are supposed to looks like and can offer some suggestions.
          • 23010
          Like this:
          • tnrtt
            • 156
            It only happens on side 2.
            • Rusty.Harris
              • Jan 2021
              • 639
              Which doc feed?
              MR3031 or MR4000?
              • tnrtt
                • 156
                MR4000. does it from computer also
                • djbass
                  • May 2008
                  • 168
                  It's still not clear exactly what is happening. You describe a white strip 2 and 3/8 inches from the trailing edge, but your example photo doesn't show that problem (possibly due to compresson?), so it's hard to say what the cause could be, are you able to show a clearer example of what is happening.
                    • 23010
                    Where is that example?
                    • tnrtt
                      • 156
                      Since it only did it on side 2, I swapped out the right side door/duplex assy. That took care of the problem. The problem in that assy? Ignorance and apathy. Don't know, don't care.
