6LK42546000 ASYS-SCRAPER-10-45-H38X apparently is on back order.
Most of the time, when rebuilding a fuser, the teflon is scratched, causing the toner to build up
on the scraper, which then digs into the fuser belt requiring replacement.
Had an idea. I peeled off the teflon tape that covers the scraper and stuck on a strip of
"plumbers tape". (no sticky tape substance). It's VERY thin. Then after install, adjusted
the gap per the manual. I've got a test mule running with it for over an hour. It's holding
up quite well. I've got the fuser out letting it cool, then will try it again.
Not a permanent fix, but, at least I can get some fusers rebuilt and back in circulation.
