KD1058, self identies as a KD1059
  • Rusty.Harris
    • Jan 2021
    • 634
    New setup, after easy setup, machine rebooted, showed close LCF drawer which was interesting
    because it had the paper feed unit, not the LCF. unplug/reconnect harness, checked firmware
    nothing out of the ordinary.
    Called the hotline, said hang on...I've seen that before. Then he pointed me to the bulletin.
    On the LCF, "due to supply chain issues" you have to connect the harness from the deck, to the
    individual connectors. Yellow to Yellow, white to white.
    BUT on the paper feed deck, you connect yellow to white and white to yellow.
    Forgot about that bulletin.
    Who in their right mind, thought it would be a good idea to do it that way?
    • 23009
    Re: KD1058, self identies as a KD1059
    Thanks for the information! Who'd have thought? =^..^=
    • Vincent128
      • Sep 2015
      • 349
      Whoever said copier engineers were in their right minds.
