Toshiba ES4505AC Developer spewing from housing
  • buzz
    • Aug 2013
    • 288
    I don't work on Toshiba much, but found it interesting that the magenta and cyan developer seems to be spewing carrier out of it's housing, (rear gear area and left side chamber through the seam). I need to definitely replace carrier but was questioning to replace all four assemblies, or top DV covers as well.
    Any feedback on this?
    Is this a sign all 4 may be going bad?
    Do you change all 4 units at this point?
    Dev CLR only 30k each, with a drive count of 400k
    • 22999
    Re: Toshiba ES4505AC Developer spewing from housing
    The developer auger shafts, seals, bearings, and gears do fail. Just doing a simple developer change is a very short term fix.
    You can rebuild those developing units, that's what we did. You can also buy whole developing units, but they're quite expensive. Two of the units failing is not a predictor of failure of the other developing units. If there isn't any developer or toner in the gears on the back of the developing unit, wait until they fail.
    When you empty those developing units, it's important to open the the air duct under the mag roller, remove the toner sensor, vacuum out the developer housing duct (and the rest of the developing unit), and knock the teaspoon or so of developer out of the toner sensor (never vacuum the toner sensor). The developer collected in the toner sensor will throw off your toner density readings. Should you decide to buy developing units or rebuild, the developer is not included. It must be ordered separately. If you want a parts list for the rebuild, let me know. =^..^=
    • buzz
      • Aug 2013
      • 288
      Originally posted by b[ATTACH=CONFIG
      53249[/ATTACH]lackcat4866;2143750]The developer auger shafts, seals, bearings, and gears do fail. Just doing a simple developer change is a very short term fix.
      As always, thank you so much for the extensive feedback and tips, very much appreciated. I'll probably do a minimum rebuild with new carrier and see how it fares. Precision has each color at $1700 a pop. 😬 Yikes
        • 22999
        Rebuild developing unit:
        auger (6LK48904000)
        auger (6LK48956000)
        bearings ([4] F0-01959000)
        seals ([4] 4401949290)
        gear 29T/coupler (6LK48906000)
        Gear 29 (6LK48905000)
        Gear 42 (6LK48908000)
        Mag Roller Gear (6LJ54058000)
        D-FC505K (6LK49016300).
        If you just replace the developer I'll give it 4 weeks before the issue returns. =^..^=
        • Rusty.Harris
          • Jan 2021
          • 623
          One other thing...it's kind of a sore spot with me. The "oil seals" 4401949290,
          that part number dates all the way back to the 80's. (most parts now start with 6Lxxxxxxx)
          Up until the newest machines, the SOP was to add Alvania #2 grease with the amount being
          "two grains of rice" to keep the seals lubricated.
          We notice a LOT of developer failures with developer leaking out of the back of the developer
          units, but, only in the winter, when the humidity gets very low due to the cold weather, and
          for some reason, people turn on their heaters to stay warm. In the spring/summer/fall it's not
          too bad, because we live in an area where the humidity is pretty high. So, when we started
          having issues, when I would rebuild them, I put the grease back into the seals. Guess what?
          Our developer leakage problems STOPPED!
          Amazing! The seals don't dry out, become brittle and allow the developer to leak past the OIL
          seals.
          It's up to you, but we put it back in, because it's the same part number going back around 40 years
          and it always had grease added to them. Recently, they changed the description from oil seals, to V-ring
          seals...gee, wonder why?
            • 22999
            the description from oil seals, to V-ring seals...gee, wonder why? ...
            That's an old time tech trick, to extend the life of those rubber seals. =^..^=
            • stooey187
              • Mar 2016
              • 9
              What type of grease did you use Rusty? I'm assuming applied to the outer side facing the bearings/ bushings.
              One other thing, I know bearings seem a good idea, however I'm finding a few of them locking up, something bushings never did!!
                • 22999
                Originally posted by stooey187
                ... One other thing, I know bearings seem a good idea, however I'm finding a few of them locking up, something bushings never did!!
                The bushing don't seize up, sure, but they do oval out, causing the seals to fail. Typically the bearings last considerably longer than the bushings. I'll take a bearing every day over a bushing. =^..^=
                • Rusty.Harris
                  • Jan 2021
                  • 623
                  I never use grease on the bushings, if they are oilite bushings. What I do on those is place them on my finger, fill them with tri-flow, then
                  pinch them between my fingers until the oil starts to ooze through the pores of the bushing.
                  Then, I simply wipe them dry and put them back into the machine. (if they aren't worn out).
                  • Rusty.Harris
                    • Jan 2021
                    • 623
                    Alvania #2. It's kind of a brown/orange grease.
                    P/N: 41303711000
                    • tsbservice
                      Field tech
                      • 7977
                      Isn't that described in SH? I remember we always put this expensive Alvania grease on oil seals... still terrible design Toshiba developer units failed mightily. You can easy compare with KM developer unit untouched 1/2 million prints and no way to fail mechanically.
