6506AC E010
  • tnrtt
    • 156
    6506AC E010
    Have a 6505 ac e010 won't clear. Fuser transport sensor checks fine, changed it anyway. According to the manual, ADU pcb is bad. Changed that, PFC pcb, logic pcb, ADU interface cable and even the fuser. No luck. Machine has 179k on it. Out of ideas.
    • 23010
    Re: 6506AC E010
    If it's a new sensor with good connections, but does not pass the sensor check (Perform the input check: FS-03-[ALL]OFF/[2]/[C], FS-03-[F1]ON/[5]/[F]), then I'd change the ADU PWB. =^..^=
    • tnrtt
      • 156
      Re: 6506AC E010
      Changed the sensor, then ADU PWB. Grasping at straws at that point. Tried PFC and Logic PWB's, ADU to main machine wiring harness.
      • Blizzoo
        • Aug 2013
        • 611
        Re: 6506AC E010
        Does the machine sense when the duplex door is opened/closed and the bridge unit?
        • tnrtt
          • 156
          Re: 6506AC E010
          Yes
