e Studio 2500ac wanted firmware
    • 23003
    Re: e Studio 2500ac wanted firmware
    Originally posted by lazzimau
    ... do you have a manual to disassembly the printer? ...
    I do have this manual. I occasionally share manuals with members of long standing, and members that contribute to Copytechnet. Some members contribute with a financial donation to support the website. Others contribute by assisting other members with their issues.
    ... is it a normal 2.5 hdd?
    It is not a normal 2.5 HDD. It's a Toshiba Wipe Drive that encrypts the data. You cannot substitute another type. =^..^=
    • lazzimau
      • Jan 2023
      • 8
      thanks.
      where can i buy it?
      regards
      • Logged-on
        • Sep 2010
        • 197
        try precision roller, precisionroller.com
        • lazzimau
          • Jan 2023
          • 8
          #19
          i can't find Toshiba Wipe Drive
          • aalex_bom
            • Jan 2008
            • 214
            #20
            could you try SSD 2.5 , sure thing
            or order Ebay, Amazon
              • 23003
              #21
              Search for part number G0-00732000 or G0-00733000. =^..^=
              • lazzimau
                • Jan 2023
                • 8
                #22
                thanks a lot, i'm looking for a new hdd...
                • jacal78
                  • Jul 2023
                  • 3
                  #23
                  Hi guys,
                  I have a Toshiba e-Studio2500AC and my current issue is. I have a error F101 which we already know is a firmware update. I have a current firmware for this machine and for some odd reason I am not able to upload into the machine. Had this firmware as a zip file. 1st I unzipped the file, then I extracted the file and then transferred all the files into a thumb drive. Took the thumb drive and plugged into the machine. Booted the machine into state #49 which is firmware updates take place. Selected update firmware and machine states that there is no folder associated for the update to take place. Question, am I doing something wrong? Possible. Can someone please guide me into right direction on how to do this smoothly. Incase, I need a new HDD, how do I transfer info from the old one into the new or when you do the firmware update it has all those information.
                  Thank you in advance for those who can offer their help
                  jacal
                  • jacal78
                    • Jul 2023
                    • 3
                    #24
                    Can anyone here guide me on how to correctly extract files so that I can upload to the machine more smoothly
                    jacal
                    Originally posted by jacal78
                    Hi guys,
                    jacal
                    • aalex_bom
                      • Jan 2008
                      • 214
                      #25
                      jacal
                      hi Jacal,
                      1. You should need to follow the service manual.
                      2. check your USB stick compatibility, used to under 8G.
                      3. check firmware source.
                      btw, you can't transfer data from the old HHD to the new one.
                      • Blizzoo
                        • Aug 2013
                        • 608
                        #26
                        Hi guys,
                        jacal
                        You need to unzip the Firmware file on your USB root, basically your firmware folder file on your USB should look like 2505AC_5005AC and inside this folder you must have all the necessary firmware files.
                        • jacal78
                          • Jul 2023
                          • 3
                          #27
                          Hi guys,
                          I tried to update the firmware but I got this instead... "Loadable Media Not Found in USB"
                          • aalex_bom
                            • Jan 2008
                            • 214
                            #28
                            Hi guys,
                            1. format USB stick, unzip the firmware source then copy the folder "2000AC_2500AC" to USB.
                            2. try another usb Port, change USB stick or Firmware source.
                            • quangtinhcopy
                              • Jul 2023
                              • 18
                              #29
                              Originally posted by 123Stairs
                              Hi.
                              Can someone help me? I am looking for firmware for the eStudio 2500ac printer. I had an error F101 13 and from what I found out I need a new firmware.
                              Lest there be a mistake, I enclose the plate from my printer.
                              [ATTACH=CONFIG]54635[/ATTACH]
                              [ATTACH=CONFIG]54636[/ATTACH]
                              Hello I have this firmware.If interested, contact me via email at whatsapp 84945948548 and email : kudoshin1994@gmail.com
                              • mark1218
                                • Sep 2023
                                • 6
                                #30
                                May I have this firmware? my email: LD1218@gmail.com
