Toshiba E355 Code C410
  • AISI
    • 49
    [Error Code] Toshiba E355 Code C410
    I replaced Thermistor check fuse and Lamps OK Machine come on, goes to warm up and back to C410. Fuser unit not hot.
    • 8346
    Re: Toshiba E355 Code C410
    ... this old dog is done. No longer supported by Toshiba Tec. Discontinued in Feb 2012.
      • 23010
      This was an odd one:
      Tray #1 shows "Load Paper" when full. C130 is stored, on eS-355SE.
      Logic board does not engage the lift motor for a long enough time.
      Replace logic board (6LH60482300). Reset C410 error in 08-400. Run 08-4582 to copy EEPROM data to SRAM. Reset maintenance modes 6S-2 (all were at 99999999).
      Logic PWB and wiped SRAM. What are the chances of that? Personally I wouldn't spend more than $50 to fix this machine. =^..^=
