eStudio 2000ac keeps rebooting.
  • Nifty
    • Sep 2020
    • 9
    G'day Legends.
    Turn this machine on, it boots up, then within 2-3 minutes shuts down and restarts.
    Anyone had similar or any suggestions??? (have swapped power supply).
    Cheers
    • 22994
    Re: eStudio 2000ac keeps rebooting.
    I think that I'd re-format the HDD, then reload firmware. You'll lose the addressbook and shortcuts also. There's probably no way around that unless you have a clone file.
    You may find that the HDD is toast, and have to do the whole thing all over again with a new HDD. =^..^=
    • Nifty
      • Sep 2020
      • 9
      Thanks mate. Won't stay on long enough to do firmware so will try HDD.
      Cheers
      • Rusty.Harris
        • Jan 2021
        • 645
        Try this trick...I've had some over the years that would reboot...
        Open the side door/front door, kill the 24 volts and see if it will boot up.
        At least it would allow you to get into service mode Pwr>FC/Start or
        Pwr>Home/Start
        • Nifty
          • Sep 2020
          • 9
          Thanks guys. Was HDD of course.
          All good now.
          Cheers.
            • 22994
            Congratulations on your success! Thanks for posting back. =^..^=
