3525/MR4010/20 C558 on power up out of box
  • Rusty.Harris
    • Jan 2021
    • 632
    Boy, I'm gettin' all the good out of the box ones!
    3525/4010/20 DSDF, Finisher/hole punch.
    Before it gets to the logon password, about 8 of 9 it
    throws a C558 error. Code is NOT in the book. Thought
    I looked at it incorrectly since there is a C55B code.
    One at a time, disconnected the Finisher, LCF no change.
    Disconnected only the multipin connector for the DSDF and
    it booted, finished easy setup, passed paper (ruling out the C55B error).
    After that, connected everything, reflashed 1725 (all firmware was the same
    level). Still tossed up the 558 error. Checked all DSDF connectors & pins.
    Pulled the HDMI cable & board. Came up with a C550 which IS in the book.
    Case opened with TABS. Just waiting on ATSG to figure it out.
    • 23008
    Re: 3525/MR4010/20 C558 on power up out of box
    I would have thought that the HDMI cable would have done the trick. It's going to be a communication error, like all the errors in that group ... most likely between the DSDF and the scanner board. Do you have a different DSDF to try on, just for diagnostic purposes? =^..^=
    • Rusty.Harris
      • Jan 2021
      • 632
      Yeah, we thought about that, but the board connector to the system board on the new style is different that the older DSDF...go figure.
        • 8197
        ... the old style did not have the Double Feed Detection system in the MR4020 Doc Feeder.
        • Rusty.Harris
          • Jan 2021
          • 632
          I see where they releasee version 1733, installed that, still pops the code.
          Just have to wait for ATSG to figure it out.
            • 8197
            ... I am disappointed that V1733 did not address the issue of the issue of the Template Conversion Utility not bring over \\ when creating scan to folder paths.
            You have to manually enter \\ for each Template for the "Execute" command to work.
            The Tempates work on the LCD panel but not in Top Access unless you manually enter \\ .
            • Rusty.Harris
              • Jan 2021
              • 632
              We are suppose to FINALLY receive a batch of 4010 DSDF's to complete an order for a college. I think I'll pop one onto the machine
              with the "unknown" C558 code. If it goes away, I'll pretty much know it's a DSDF issue. If it doesn't, I suspect it's gonna need a
              system board.
                • 23008
                system board.
                Let us know how it goes. =^..^=
                • Thayer
                  • Dec 2017
                  • 107
                  Clone machine like normal, Then export templates.
                  When you import templates, you will see in small print convert templates to new style or something like that.
                  You will get the old school templates back.
                  I haven't seen it but I heard from another tech.
                  • Rusty.Harris
                    • Jan 2021
                    • 632
                    Well, it isn't the DSDF causing the issue.
                    Swapped out the entire DSDF with another MR4010 (including the extra interface board)
                    After warming up just before the main screen, it popped up with C558 again.
                    Looks like a system board issue, but I'll wait on ATSG to figure out what the code means.
                    • Blizzoo
                      • Aug 2013
                      • 608
                      If possible, could you check the condition of the DSDF plug on the machine side behind the frame (not the HDMI, if not already checked)? Check if the wires behind the plug are insterted/connected. I remember someone having a pin not inserted properly into the plug, I think was a similar ode can't remember.
                      • Rusty.Harris
                        • Jan 2021
                        • 632
                        FOLLOW UP
                        TABS finally figured out what the code is.
                        Considering I swapped out the entire DSDF (including the daughter board for 2nd side), the hotline agrees
                        it has to be a system board. Got one on order.
                        Will post when I get it, if that corrects the issue.
                        • Rusty.Harris
                          • Jan 2021
                          • 632
                          Final follow up
                          ​System board corrected the issue.
