MJ-1112 movable tray issue
  • Rusty.Harris
    • Jan 2021
    • 633
    Tech had a call on an MJ-1112. Customer said the movable tray slammed to the bottom. Raising it up manually
    just caused it to drop again. When tech was on sight, he noticed metal shavings around the back. Upon further inspection
    he found the 6LK57402000 Worm-Wheel-10-6-Tray-T slightly impacted. But the real killer was the
    brass gear 6LK59421000 Worm-Gear-Tray-RBT3-PBF which was chewed up. Being a metal gear I figured it
    would be worn more than the plastic gear. Tech said he found no indication of the gears not being aligned
    properly. Not sure what chewed them up.
    • 23009
    Re: MJ-1112 movable tray issue
    That's impressive. It's really common to see these gears damaged on Konica Minolta finishers ... but I don't think that I've ever seen it on the Toshibas. The KM gears are Delrin, and they split or shatter ... never wear. I don't see any sign of grease ... maybe they did not get the customary dab of grease at the factory, or it was misguidedly cleaned off.
    Thanks for sharing. =^..^=
