Tech had a call on an MJ-1112. Customer said the movable tray slammed to the bottom. Raising it up manually
just caused it to drop again. When tech was on sight, he noticed metal shavings around the back. Upon further inspection
he found the 6LK57402000 Worm-Wheel-10-6-Tray-T slightly impacted. But the real killer was the
brass gear 6LK59421000 Worm-Gear-Tray-RBT3-PBF which was chewed up. Being a metal gear I figured it
would be worn more than the plastic gear. Tech said he found no indication of the gears not being aligned
properly. Not sure what chewed them up.
