Toshiba estudio 257 dead machine only gree power light
  • briko
    • Nov 2015
    • 22
    Hi i have te Toshiba estudio 257 and the machine is completely dead nothing on display no error codes no fan moving only light green power light.If someone had experience with this problem i hope gona help me
  • Rusty.Harris
    • Jan 2021
    • 634
    Re: Toshiba estudio 257 dead machine only gree power light
    Couple things...pull the fuser out, see if it will power up.
    After that, disconnect any ribbon cables from the system to the logic, along
    with the "power" cable on the logic (it's usually the larger wires, red, blue, white, black).
    See if it will try to power up.
    Also, double check the low voltage power supply for any blown fuses. Check them with
    a meter. The glass fuses sometimes will pop, right under the metal cap and the fuse wire
    will look ok.
    • mgipa
      • May 2020
      • 49
      board SYS
        • 23009
        I was sent out to install the SECOND power supply in two days on a LoireX. I discovered a blown fuse on the power supply. I changed out the fuse and powered up. While it was powering up there was a HUGE SPARKFEST from the fuser. Apparently, the last person to rebuild the fuser hadn't quite got the "C" clip completely onto the roller, and it was shorting out the lamps. I installed my last fuse, and returned with the second new power supply unopened. =^..^=
        • briko
          • Nov 2015
          • 22
          I disconect everything from the system board I disconnect the fuser same situation dead machine only green power ligt
          I think maybe is power supply im gona order and i chachkit maybe gona power on thanks a lot
          • briko
            • Nov 2015
            • 22
            Originally posted by mgipa
            board SYS
            You meen system board are you have expiriance with this problem
            • Rusty.Harris
              • Jan 2021
              • 634
              Hated those things. If it popped off just right, those clips would weld themselves to the lamps.
                • 23009
                Don't you know it! I just got lucky.
                It was fuse F101, 20A (15 amp holds, if it's not a dead short). I would definitely check that first. =^..^=
