this machine is copying light on the bottom of page. The prints from the computer are fine. Doesnt matter if you run off glass or dsdf. as far i could see there are no baffles to change the amount of light . The troubleshooting guide mentions (a shading correction plate).If there is one i dont see it. thanks in advance!!!
toshiba 3508a
Re: toshiba 3508a
Couple things. Any chance the clips that hold the mirrors have popped loose?
Next, double check between the lens & the CCD element for any dust. If the environment
is "dusty" sometimes dust can get on the back side of the lens and the CCD. -
Re: toshiba 3508a
A sample would be nice ... and consumable yields. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
