4508 E-580
  • Rusty.Harris
    • Jan 2021
    • 633
    4508 E-580
    Passing this along from one of my field techs.
    Only jams when duplexing obviously, E580. Ran the input/output for the sensor, checked
    ok. The code says the TRAIL edge isn't clearing the sensor, but the paper had made it to
    the alignment roller. Tried different size paper, different trays, checked the exit assembly
    for the gunk on the bushings. Had another ADU assembly at our warehouse, swapped it
    out and it worked. When he laid it down, he heard a noise. Come to find out the fan
    above the sensor (Ribon pg 34 # 25) had popped out of its holder and the blades were
    touching the sensor enough that when the paper passed through, the sensor arm would
    stick on the blade. When you opened & closed the door, it was enough movement to reset
    the sensor.
    • 23009
    Re: 4508 E-580
    LOL! Something like this eS4508?:
    • Rusty.Harris
      • Jan 2021
      • 633
      Re: 4508 E-580
      [ATTACH=CONFIG]61297[/ATTACH]
      From what he told me, EXACTLY!
        • 23009
        Re: 4508 E-580
        My conclusion was that my customer was slamming the right door excessively hard. I was able to re-install the fan blades and the fan functioned properly, then I added a coathanger "guard" to prevent the blades from falling completely off. I've never had much luck changing customer behaviors. =^..^=
        • Rusty.Harris
          • Jan 2021
          • 633
          Re: 4508 E-580
          I got in trouble once about a dozen years ago from a customer who was slamming the door on a 5540. The next time I got a call, I waited until 4pm to respond
          because I knew what they had done.
          Customer asked me why it took so long I pretty much said well, you aren't operating the machine as i instructed you to prevent this from happening, so i put you
          at the bottom of the list and did others first.
          They called in to complain...boss asked what I did, told him, just laughed and said don't do that again.
          But, it worked! They finally stopped slamming the door. (jams were because their cheap paper curled too much)
            • 23009
            Re: 4508 E-580
            LOL!! Sounds like something I'd do.
            You could break the plastic features where the 2nd transfer roller fits to the primary transfer belt. I've replaced a lot of those.
            The hardest ones to diagnose were just fractured, but the crack only opened when the door is closed. =^..^=
            • Rusty.Harris
              • Jan 2021
              • 633
              Re: 4508 E-580
              Hey, thought you might want a tweaked photo of that. I pulled a bit more detail out of the
              shadows & killed down the noise a bit, then rotated it so when one of my techs looked at it,
              his head didn't have to tilt sideways LOL.
              • tsbservice
                Field tech
                • 8020
                Re: 4508 E-580
                Heh...
                Rusty with 5540 you don't mention analogue ones...learned their soft spots being constantly week or two at the same customer.
                • Rusty.Harris
                  • Jan 2021
                  • 633
                  Re: 4508 E-580
                  Heh...
                  Oh the stories...I could write a book after 43+ years in this mess.
                  My first one was a b&w sharp SF-810 in Marshall Mo. I had been in this about a week, ya know back in the day it was OJT. Riding with
                  a guy. "lines" all over the copies. Looked inside and the drum looked like a chicken had scratched it. This was in a small rural church
                  with a 156 year old "church lady about 5' tall.
                  We asked her if she had a paper jam and she said yes. I asked what she used to get it out.
                  She opened a drawer and pulled out one of those huge old hickory butcher knives and wielded it like a samurai warrior!
