How to configure a GD1370NA Fax board to work with a Grandstream HT801 ATA
    • 8304
    I wasted a good hour trying to get a e4525AC/GD1370NA fax board connected to a GrandStream ATA to send a fax.
    I played round with all kinds of settings in Field Service 13 fax mode but I could not get the fax board to transmit a fax.
    I could see the customer's fax trying to connect with my same fax board and I got all of the usual handshake noises but the fax would not transmit.
    I finally discovered the customer is using a Grandstream HT801 ATA (analog telephone adaptor) but I am unable to give the IT Manager any advise on how to configure it.
    Does anyone have any experience with this?
    In the past, I was working with a Cisco ATA. This large custoner's IT Dept was convinced it was the copier's faullt but in the end they had to enable a passthrough
    • 8304
    Re: How to configure a GD1370NA Fax board to work with a Grandstream HT801 ATA
    ... there are YouTube videos to watch on ATA switches but this seems to be IT's responsibility.
    I got dial tone and I have proof the customer's fax board tried to connect to my same model fax board.
    • mojorolla
      The Wolf
      • 2639
      When fighting VOIP I always:
      -make sure the actual phone cord is a 2-line, not the old style 4-line
      -drop baud rates to 9600 (tx & rx)
      -turn of ECM
      -set coding to MMR
      VOIP is also very susceptible to network jitter and packet loss. The VOIP line should also be uncompressed (g 711 codec)
      You can find a good read here:
      Make Faxing over VoIP work with these fax settings for VoIP (voipmechanic.com)
      • Rusty.Harris
        • Jan 2021
        • 639
        I usually use the settings that TABS says to use.
        These settings I came up with a LONG time ago when VoIp started.
        When I have one that just won't work, I send out this batch. Most of the time it fixes
        the issue. 13-337 you might want to disable if the customer doesn't want to hear
        the noise up to Phase B.
        Some of these probably aren't needed any more, but I just never changed them.
        104 Dial tone check PSTN,DTC or LCC, Line1 0
        110 Dial tone check PABX, DTC or LCC, Line2 0
        149 Receiver attenuator, Line 1 1,2
        200 Exchange Type POTS/PABX, Line1 1
        210 Exchange Type POTS/PABX, Line2 1
        224 Dial tone check PSTN, DTC or LCC, Line2 0
        230 Dial tone check PSTN, DTC or LCC, Line2 0
        279 Receiver attenuator, Line 2 1,2
        325 TX attenuator, Line 1 11-15
        329* Cable equalizer for RX 1
        331 Echo Delay 0
        335 Modem Default speed 1
        337 Speaker sound on up to Phase B (customerpreference) 1
        346 Recording width capacity declaration 1
        391 ECM Function 0
        430 TX attenuator, Line2 11-15
        434* Cable equalizer, Line2 1
        512 Image error rate 3
        565 Fallback condition for transmitter, Line1 8
        569 Maximum Line Speed 6
        571 Sub/Sep/Password 0
        574 Coding compression 1
        611 Fallback condition for transmitter, Line2 8
        618 Maximum Line Speed 6
        619 Rx capacity declaration, Line1 0
        620 Rx capacity declaration, Line2 0
        518 Duplex received fax 1
