Toshiba e-studio 901 with error code SC 750
  • DanM
    • Jul 2025
    [Error Code] Toshiba e-studio 901 with error code SC 750
    I have a machine that is down with an error code 750. Does anyone have any suggestions?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    I do not have the 901 book but it should be close to the 900 which is:
    SC750: Cover Interposer Tray Bottom Plate Motor Error
    Definition [D]
    One of the following events occurred:
    • After the motor starts to raise the bottom plate, the bottom plate position
    sensor does not detect the plate at the specified time (3 s).
    • After the motor starts to lower the bottom plate, the bottom plate HP sensor
    does not detect the bottom plate.
    Possible Causes
    • Bottom plate position sensor defective
    • Bottom plate HP sensor defective
    • Bottom plate lift motor defective
    • Cover interposer tray main board defective
    • Motor connectors loose or harness defective
    • DanM
      Thanks for your reply. I don't have the cover interposer, just the SR5000 finisher. Have been all over the lift sensors etc. another tech replaced a bad lift motor. It damaged the finisher board which was replaced. Had J110 codes at times before the SC750 indicating shift tray. Couldnt find a problem there either. Problem is nearly constant when using finishing features (paper exits to shift tray). OK on basic copying using top tray. Any other help would be appreciated. Thanks.
