help for reset e-studio 25-35-45
  • etsmultan
    • Apr 2007
    • 131
    hi,
    pls tell me reset code for e-studio 25-35-45.my email is etc_new@hotmail.com and ets_multan@yahoo.com
  • jawir
    • Aug 2007
    • 107
    Originally posted by etsmultan
    hi,
    Hi,
    what kind of reset you need it?
    rgds
    • etsmultan
      • Apr 2007
      • 131
      Hello Jawir,
      I want to reset code for refresh copier,PM counter and any one you have.
      • jawir
        • Aug 2007
        • 107
        reset
        Hi,
        for reset the pm counter you can use 08-252 you can put zero in there. For reset the drum counter, fuser, and wire you use 6-start than choose 2 for drum, 3 for wire and 4 for fuser.
        regards
        • KHAN
          • Aug 2006
          • 261
          Studio 25-35-45 Reset
          thanks Jawir,
          but What Is 6-start To Reset Drum,wire And Fuser Can You Explain In Detail Please ?
          • jawir
            • Aug 2007
            • 107
            HI,
            6+Start is PM support mode. the easy way to reset drum/wire/fuser. Beside that you can reset in 08 mode.
            Just easy way put the code (2/3/4) than control panel will appear initialize and cancel for confirmation. just push initialize for resetting.
            regards
            • jawir
              • Aug 2007
              • 107
              Hi,
              For make sure this:
              6 (button) and start (button) press together.
              regards
              • KHAN
                • Aug 2006
                • 261
                Reset Toshiba 25-35-
                thanks For A Usefull Information,
                you Mean That I Press 6+start Together And Then Trun The Copier. What Is 2/3/4 Code For ?
                thanks A Lot.
                • jawir
                  • Aug 2007
                  • 107
                  Hi,
                  As I mention before. based on the each code is for resetting :
                  1. For auto toner adjustment
                  2. Drum life counter resetting
                  3. Fuser unit counter
                  4. Charger wire separation resetting counter
                  Rgds
                  • cjmbiomen1222
                    error code
                    hi,
                    please tell me what is F100 error code at toshiba studio450...
                    thnks!
                    • Mr Spock
                      Vulcan Inventor of Death
                      • Aug 2006
                      • 2064
                      Originally posted by cjmbiomen1222
                      hi,
                      thnks!
                      Hard drive failure. You will need to replace and reload the operating system (firmware on this model).
                      • jawir
                        • Aug 2007
                        • 107
                        Hi,
                        F100 is HDD fail. I think you have to replace it.
                        rgds
                        • PTAI
                          • Oct 2007
                          • 38
                          hi !
                          can you guide me to reset the total counter, please!
                          • jawir
                            • Aug 2007
                            • 107
                            Hi,
                            F100 is HDD format error.other wise your HDD is broken. Try to format it first by using 08-690 put 2 than start. If this way cannot solve that is mean you have to Change with the new one.
                            rgds
                            • hp_241112
                              You can tell me the way to reset Total counter, plz ?
