Toshiba 810
  • RonMac
    • Oct 2008
    • 57
    [Error Code] Toshiba 810
    Getting Error Code C47...Replaced IH Board, Fuser and Hard Drive. Still can't reset machine. I know it's a power voltage problem. Can anyone shed some light on this problem? Thanks....Ron
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Did you reset 08-400 to 0. Sometimes you have to have the front door open to get to the reset screen. Also check the plugs on the back of the fuser and the adu unit. If these have paper in them or one side or the other is cracked it will give this message.
    • YouthAttack
      • Mar 2010
      • 37
      oh man good luck. um.. ive seen the fuser connector in the back of the machine get a hairline crack and code out. also the frame of the adu where the fuser sits, make sure its not tweaked. ive seen the logic board also code out fuser codes.
      • RonMac
        • Oct 2008
        • 57
        Thanks for all the help and information. Still not up and running yet, Will try again tomorrow to get it working. Thanks again....I checked all your suggestions. Ron
        • ToshibaTech
          • Apr 2007
          • 580
          Maybe a dumb question but did you check the thermostats? I have also seen the front door interlock get stuck down (closed.) And what will happen is when the copier door is opened and the fuser drawer pulled out the machine will instantly code... can't remember if it gives this code or not.
          I will not give you service manuals or firmware.
          • RonMac
            • Oct 2008
            • 57
            Toshiba 810
            Not a dumb question at all. Did check thermostats of course. After resetting 08-400 screen display indicates "close duplexer cover". DUH? There is no cover. Usually changing hard drive will clear this sympton, but after changing hard drive the screen display message remains. Also get code F10 (hard drive prob.) after resetting 08-690, error code F10 disappears but message remains with C47 error code. Been a Service Mgr. and Tech. over 30 years and this one has me baffled! Thank you for any light you can shed on this problem. Ron
            • jamesyboy
              toner monkey
              • Jul 2010
              • 188
              theres a switch inside the machine that is activated ehen the adu trans assy is locked in change the switch
              • cishler
                • Jul 2009
                • 8
                Some of the thing I have seen in the past are bad therostates and holders I usually replace both of them and the holders at the same time, bad thermistors or the harness gets pinched under the red cover, you may want to replace the fuser connector and ADU connection and replace these as a set. I have had several unites over the years were these connectors start to fail due to a poor connection. Their is a factory update for the fuser conector you may want to make sure its install. Some other hints leave the fuser /ADU unit pulled out and reset 08 code 400 then try to start the unit if the c47 code comes up right away and the fuser unit did not start to heat up it is probley the conectors, IH board or logic board. I hope that helps.
                • PIPSTONE
                  PIPSTONE
                  Check connector under the fuser the one to the ADU connector but check it on the inside the wire harness gets pulled out of the Frame connector which plugs in from both sides.
                  • jonezy999
                    just one copy??
                    • Feb 2010
                    • 952
                    I have had to pack out the connector on the back of the fuser with a few washers to push it into the plug in the machine harder. Also had the shielding on the heat bar slightly damaged cause this.
                    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                    • makaule
                      • 74
                      had the same problem with my studio 650, getting errors C46, C47, C48 for several times every day. It was like splinter in my ass. Changed main door switch and now no more codes for more than 2 weeks. You can hear switch arching after closing front door ,try adjusting switch pusher at first, if arching still heard then change main switch. Don't forget 08-400 to 0. Sorry for my englich. Good luck !
