Nielbatiks: Don't end your title with the word print or you'll get a "print screen"
    • 23009
    ... and nobody can respond to your thread.
    Just out of curiosity why are you using a 451C color print driver on a black & white copier? =^..^=
  • Neilbatiks
    • Jul 2014
    • 9
    Re: Nielbatiks: Don't end your title with the word print or you'll get a "print scree
    hi i new here so pardon for that,
    yep 451C divers and it works on vista for toshiba 232 copier,
    please advices about the driver that i should be using
      • 23009
      Do you see something you like here?:
      e-STUDIO233 Monochrome MFPs: Support & Download - Toshiba e-STUDIO
      • Neilbatiks
        • Jul 2014
        • 9
        Hi !
        thanks you for your enlightening
        but i wonder how can i use advanced printout controllers in this drivers,
        EX- Duplex printing, black mode
          • 23009
          I'm confused. You have a Fiery attached to your e Studio 232? You should have no trouble selecting black and white printing ... since a 232 can only print in black and white.
          I'll definitely need more specifics. =^..^=
          • Neilbatiks
            • Jul 2014
            • 9
            Ok here it goes,
            Toshiba 232,
            S/N CRC739701
            I can use the black mode, what i try to say is that with the 232 drivers i can control the printouts in advanced method, like this,
            By the way this picture is from my other computer with Win vista 32bit OS works fine
            and MY problem is that i had install 451C drivers for Win 7 64bit OS computer and It gives me the same results, but in past 2 weeks I cant make print outs with this copier, print job is in queue but wont print not even a blink in the copier for data received
            and for further details,
            I can use it as a monochrome scan device and I can access it hard disk via e-STUDIO File Download soft in Win7 computer,
            What is the problem here ?
              • 23009
              For starters I would install the correct print driver. A black and white copier cannot make any sense of color print data. I really doesn't matter it it ever worked properly or not with the wrong driver. Delete the driver on your PC. Download an e Studio 232 driver. Install it. =^..^=
              • Neilbatiks
                • Jul 2014
                • 9
                ok,
                I will follow it, see whats happen,
                • Neilbatiks
                  • Jul 2014
                  • 9
                  Originally posted by Neilbatiks
                  ok,
                  OK
                  Here what I did !!!!!!!!!!!!
                  I removed every device in the devices and printers area relating to the copier
                  Then add a printer ---- network printer --------- found the printer
                  Have disk it for drivers and I got the correct drives from Toshiba - Photocopiers, printers and fax
                  And it was completed and here's what I got,
                  But the problem still in hand it wont print, not even blink in the copier for data received.
                    • 23009
                    Open to the Ports tab, drag open the IP address column so we can see your port designation. =^..^=
                    • sdrawkcab
                      Confused & Bewildered
                      • Jun 2009
                      • 317
                      What print enabler do you have in the copier.
                      Some days, it's just not worth chewing through the restraints
                      • Neilbatiks
                        • Jul 2014
                        • 9
                        I don't think it is a problem because I can get pints with it in the other PC (Vista)
                        Added the port list,
                        • Mr Spock
                          Vulcan Inventor of Death
                          • Aug 2006
                          • 2064
                          That is a wsd port which I do not remember that machine supporting.
                          Click add port > tcpip > enter the ip address of the copier then apply then see if you can print.
                            • 23009
                            Thank you Mr. Spock. I wasn't sure about that one. =^..^=
                              • 37532
                              I have occasionally ran into problems with Ricoh products being detected as WSD devices by Windows. If the person installing the driver uses the detected device instead a Standard TCP/IP port, it is always a problem. I have occasionally installed a print driver using the NetBIOS name of the device when I have had to go to the same customer the third time in as many months because they have changed a router and gone to a different subnet.
