Toshiba 2830C - poor copy quality on second side only
  • JOEBOOROCKSYOU
    • Jan 2008
    • 85
    have one out in the field and its driving us nuts.. only the second side (duplex) is giving the customer poor image .
    ran manual 2 sided and no problems..I know on the Ricohs you can adjust the transfer voltage on the transfer belt for both 1 and 2 sided copying.
    any ideas or help would be appreciated....
    thanks,
    Joe
    • 23008
    Re: Toshiba 2830C - poor copy quality on second side only
    I don't know if the 2830C has separate transfer voltage settings, but 2500C/3500C/3510C does, and at least on that model it does resolve poor transfer issues 2nd side on heavy media.
    • JOEBOOROCKSYOU
      • Jan 2008
      • 85
      yea , that's what i'm used too but i have searched high and low on the service manual on the 2830c and cannot find the setting...hope that's not the case...
      • arnh79
        • 468
        If the customer is using non-standard paper you can set any tray as Thick 1 Back. The "back" option means it will adjust settings to deliver a better second side transfer. But if this happens all the time on all paper types than you'll have to keep searching for a code.
        Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
