es 250 developer coming out on copies
  • barrylee66
    • Oct 2010
    • 37
    dv coming out on copies and a grey band 3 inches wide on leading edge on back of copies front to back. not on all copies but about half of them. tried a used trans roller from another machine with same results
  • arnh79
    • 469
    Re: es 250 developer coming out on copies
    Replace PU-1610. That's an old box so even if it isn't calling for replacement it's probably worn out.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • barrylee66
      • Oct 2010
      • 37
      what is pu-1610 and its only 4 or 5 yrs old I think the build date is 2010. we sell used equipment and usually only buy off lease equipment so at least 3 yrs and usually 4 . sometimes older. I just started working on Toshibas 3 months ago the older ones seem better e-232 that series
      • barrylee66
        • Oct 2010
        • 37
        oh ok the drum I knew that number looked familiar. why does everyone here and smarka now talk in code. trust me im a tech, every time I post something someone says call a tech. I have been a tech since 1992 steady. I just work on a lot of different brands. thanks for your help the drum is almost new but I will try that.
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          The part you need to change is the whole process unit. Comes as one unit on this model.
          It didn't say that I couldn't do it in the manual.
          • arnh79
            • 469
            And the whole process unit is called a PU-1610S. But apparently that's a secret code language...
              • 23010
              Whenever I see a word I don't know I punch it into Google, then I know what it means. Even the secret-code.
              Personally, I would check to see if any of your developer is pouring out through the front or rear developer seals. Especially if that pile of developer was at the rear shorting out the developer bias contact under the developer unit. =^..^=
              • barrylee66
                • Oct 2010
                • 37
                ok I put an image unit from another machine in it it worked fine for a month then it came back so I called tech support they said change the developer. I changed the developer and it has been fine now for another month. thanks for the help
                • barrylee66
                  • Oct 2010
                  • 37
                  well the guys I talked to in tech support did not call it pu-1610s he called it the image unit just like I call the I\u from any machine.
