I am getting this code repeatedly, when it happens the paper is just shy of entering the fuser - right at the trailing edge of the rubber belt feeding it into the fuser section. It will feed 2 sheets OK then stop on the third sheet. Always stops the sheet in the exact same position.
Printing on 11x17 sheets tried feeding from 3 different trays. Occurs on both single side and duplex printing. I tried blowing off the sensors at the front and back of that section.
Is there something specific I can try in component control to narrow it down?
