700i error 077-123
  • MPrints
    • Sep 2012
    • 9
    700i error 077-123
    I am getting this code repeatedly, when it happens the paper is just shy of entering the fuser - right at the trailing edge of the rubber belt feeding it into the fuser section. It will feed 2 sheets OK then stop on the third sheet. Always stops the sheet in the exact same position.
    Printing on 11x17 sheets tried feeding from 3 different trays. Occurs on both single side and duplex printing. I tried blowing off the sensors at the front and back of that section.
    Is there something specific I can try in component control to narrow it down?
  • MPrints
    • Sep 2012
    • 9
    Re: 700i error 077-123
    Still battling this problem . . . I am able to run 8.5x11 sheets fine, but 17" jams every time. Heavier stock might get a few sheets through before jamming, text weight will jam every time
    • adriansto
      • 2372
      Send me mail stoadis@gmail.com.
      I will show you some bulletins
      • steve_h
        Sorry to dredge up an old thread.
        I am running into the same issues and am curious as to what the problem actually was and how to fix it.
        • MPrints
          • Sep 2012
          • 9
          Hello Steve it has been a while but if I recall correctly I had a tech come and help me and he found that the clutch at the machine (inboard) side of that area was the problem, I think a cracked plastic gear.
          • zagrex
            • Dec 2011
            • 63
            hello your problem is not sensor registration motor.
