Xerox 7775 all trays not working including Baypass
  • Edib Vektor
    Everything can be solved
    • 15
    Hello, recently we get Xerox 7775, the problem is quite easy to explain. Every single tray including baypass
    are not working. When paper is inserted lifts are not going up, they stay's down (that ocure in every tray). Also machine register paper format.
    Does anyone know solution?
    Best regards, Edib. Cheers.
  • adriansto
    • 2384
    Re: Xerox 7775 all trays not working including Baypass
    Check for missing 24 volts .
    Tray's motor use that voltage for work.
    • bryant28282000
      • Jul 2012
      • 145
      He is right check the voltage, but did you NVM this machine? The reason I am asking because one day I took a lot of NVM setting off of a xerox machine and I had all the trays not work.
      • Givvy
        • Feb 2021
        • 8
        Hi, how do you NVM that machine.
        I have a problem where the paper jams only on the registration and have tried all paper trays and the machines still gives the same problem, have changed the the paper feed rollers and the the registration sensor but still the problem persist
        • InterfaceP
          • Jun 2013
          • 488
          Remove the pre-registration assembly and look for a small piece of paper stuck inside somewhere
          • Detonation
            • Feb 2010
            • 404
            YEah I'd troubleshoot the registration assembly as well before fiddling around with NVM
            • Givvy
              • Feb 2021
              • 8
              Hi, I have removed and checked the pre-registration assembly countless times now and there's absolutely no paper or foreign objects
              • Givvy
                • Feb 2021
                • 8
                I have done that, the bypass is also not working so I am thinking it's the motor but don't know out to run a free run on Xerox
                • Jack79
                  • Jul 2014
                  • 312
                  Check it it lifts up when you manually turn the gears located at the back of the tray.
                  • Detonation
                    • Feb 2010
                    • 404
                    Have you also checked the gear on the registration assy? You need to check from the rear of the machine. Sometimes it has a tiny crack, and the is enough not to run the registration roller at all.
                    • Givvy
                      • Feb 2021
                      • 8
                      What gear could it be cos I took out the whole Registration and I didn't see anything....I will recheck tomorrow morning but which gear specifically...and can anyone assist with the machine service manual...thanks
                      • Detonation
                        • Feb 2010
                        • 404
                        The registration assembly is driven by a motor which you can only access from the rear. The gear on this motor can crack. I *think* the part number for the whole motor is 127K39650. The gear isn't spared, but it's easy to come by through sites like Aliexpress. Shoot me a pm for service manual. I have for the DC240/250 but it's mechanically the same.
                        • Givvy
                          • Feb 2021
                          • 8
                          Hi, I have sent you a private message.
                          • big mike
                            • Sep 2012
                            • 144
                            The Parts Drop has the gear for $24. I haven't found it anywhere else for less. Have you? Please let me know if you have.
                            • Detonation
                              • Feb 2010
                              • 404
                              I found them on Aliexpress as well. Search for Lift Motor Gear 16 T 127K37681 and you will find them. It's 10 pcs for $ 20 or something in that ballpark.
