Xerox 7220 background when copying from ADF
  • Jack79
    • Jul 2014
    • 312
    Hi I am looking for experienced person advice.
    WC 7220 scan/copy fine from glass but from ADF leaves background in BW and Color mode.
    Replaced whole adf but problem persist
    Checked pins on IIT PWB
    Cleaned slit glass
    This printer was without hdd so installed a new one (did not have nvm saved and no idea if the problem was before installing a new hdd).
    What can you suggest or maybe have you seen this before?
  • magicaljake
    • Jun 2018
    • 22
    Re: Xerox 7220 background when copying from ADF
    have you performed the copy/scan calibrations?
    also in tech mode have you performed the IIT calibration with the xerox color chart?
    • Jack79
      • Jul 2014
      • 312
      Thanks for a reply.
      I did not calibrate as prints/copies/scans are perfect. Copy and scan work fine from glass. Prints are great.
      The only problem is with copy/scan from adf.
      I do not have xerox chart so have not done IIT calibration but that may help solve this issue.
      I am worry about performing calibration as on 7220 calibration is made from ADF and this can affect all copies, scans and prints. Anyway I will perform calibration as you suggested as I do not work a lot with Xerox machines.
      • Guitaris
        • Jul 2018
        • 6
        Hey Jack 79,
        I have exact the same issue now on a 7225. What was your solution for this strange issue?
        I did perform the callibration, but it comes back after a while. Restarting the engine does also solve this problem, but again in return.
        Regards,
        Originally posted by Jack79
        Thanks for a reply.
        • Jack79
          • Jul 2014
          • 312
          Hi
          I have done nvm initialisation and change 616-014 to 2 or 4 (do not remember) once machine went into non customer mode.
          • XEROX_1111_TEC
            • Aug 2019
            • 71
            Cleaned slit glass
            [ATTACH=CONFIG]40241[/ATTACH]
            That can be de flat cable that goes to the led bar or the led bar.
            I had the same issue and, in my case, it was de led bar. After substitution this issue was solved.
            • Detonation
              • Feb 2010
              • 410
              If it's the LED bar, isn't it odd it would only give the problem from the ADF and not the platen?
              • misbah711
                • Jul 2020
                • 4
                I am having the same issue , ADF is only producing colored background on duplex side, as the platen scanner is working fine.
                first it was green then after NVM initialization it changed to yellow after scanning it to computer.
                • adriansto
                  • 2392
                  Check the nvm with machine nvm sheet.
