Xerox Altalink C80xx Altboot fail, boot loop
  • xcopytech
    • Aug 2006
    • 1794
    #16
    Re: Xerox Altalink C80xx Altboot fail, boot loop
    Machine model and sd card size?
    • Mikeymikeo
      • Oct 2022
      • 5
      #17
      The machine is Xerox AltaLink C8045 with 8GB SD Card.
      We attempted to reset because of a password issues and when it rebooted it was stuck in a loop.
      Ive tried to Altboot with USB but never pushes thru. The only thing I can think of is maybe the bad files are on the SD Card?? If I am wrong please let me know.
      Thank you for your time.
      Thanks, Mike
      • adriansto
        • 2387
        #18
        Thanks, Mike
        About what password do you talk ?
        The printer administrator password can be reset..
        • xcopytech
          • Aug 2006
          • 1794
          #19
          What code you have on seven segment display
          • Mikeymikeo
            • Oct 2022
            • 5
            #20
            • adriansto
              • 2387
              #21
              We forgot the admin password and followed a video on resetting. We didn’t push Initialize when doing the first step of the video. Then followed the rest of the steps and it’s boot looping. We have a U on the led screen. I’m taking a new hdd and new altbooy usb and trying again. I’ll update when done.
              U mean problems with system software, hdd or even malfunction of SBC board. Can you post the link for that video ?
              • Mikeymikeo
                • Oct 2022
                • 5
                #22
                IMG_5191.MOV - Google Drive
                • adriansto
                  • 2387
                  #23
                  This is video of B8045 restarting probably because the UI dont communicate with SBC ( sys sw failure ).
                  I dont see what is writed on screen.
                  I asked for video with reset instructions that you used.
                  • Mikeymikeo
                    • Oct 2022
                    • 5
                    #24
                    • Jack79
                      • Jul 2014
                      • 312
                      #25
                      https://www.dropbox.com/s/jp8u81eb6h..._3314.mov?dl=0
                      ok on the 2nd part it says press 3 things then initialize. I didn’t press initialize. I think that’s what went wrong.
                      This is not a procedure for reseting admin password (from this video).
                      You need the reset code or file (depends on model).
                      Now it looks like data corrupted. Try altboot or new hdd.
                      • chubblies
                        • Jun 2011
                        • 155
                        #26
                        When you 1st turn it on, it boots from the SD card. The display you see created on the screen is all from SD, and it then boots from HDD/SD to bring the machine fully up. The fact it says B8045 suggests that the wrong image is on the SD card in my mind?
                        I would reload the SD again. Here are links with the complete disk image and HDD raw which you can use to create the SD.
                        SD image C8045-55 https://www.dropbox.com/s/epxab8ercm...8055.imgc?dl=0
                        HDD raw https://www.dropbox.com/s/atkvu5lbnz...Setup.zip?dl=0
                        • Apouthe Donald
                          • Mar 2014
                          • 82
                          #27
                          • ArdjunaMara
                            • Feb 2023
                            • 1
                            #28
                            SD image C8045-55 Dropbox - Error
                            Hello. Will you share these images? Links are not available
                            • alsid
                              • Sep 2010
                              • 27
                              #29
                              SD image C8045-55 Dropbox - Error - Simplify your life
                              HDD raw Dropbox - Error - Simplify your life
                              Hello,
                              I have some issue with C8045. I have a machine that is in bootloop. Probably the SD Card or HDD has been corrupted.
                              Looking forward for your answer.
                              Regards
                              • alsid
                                • Sep 2010
                                • 27
                                #30
                                Originally posted by adriansto
                                You must have some of these files[ATTACH=CONFIG]49907[/ATTACH][ATTACH=CONFIG]49907[/ATTACH]
                                Hello adriansto,
                                Please could you send the image file for C8045 SD Card, I have a device that is in bootloop.
                                I will appreciate any help.
                                Regards
