B8055
  • big mike
    • Sep 2012
    • 150
    B8055
    I have a B8055 showing 319.412 faults. My pws doesn't show anything for that fault. Does anyone know what it means? I assume it is scanner related since 319.410 describes scanner issues.
  • Detonation
    • Feb 2010
    • 410
    When is it showing the fault? Directly at startup? Or only when you try to scan or copy?
    • big mike
      • Sep 2012
      • 150
      It is in the history. It prints fine. Copies using the dadf are fine. I noticed the copies coming from the glass are poor, thought it may be related to a scanner cable issue. I will swap it out and bring it to the shop soon.
      • Gaffers01
        • May 2011
        • 334
        This is from The C8070 manual
        319-412-01 Scan Image Capture IIT Line Sync Integrity Error RAP
        Unexpected IIT Page Sync that typically indicates noise on the line.
        Procedure
        No CSE service action is necessary.
        • big mike
          • Sep 2012
          • 150
          That sounds correct. Thanks for looking it up for me.
          I reseated the connectors at the pwb yesterday. I'll replace it tomorrow with a good copier. It's in a hall and I will need room to work on it.
