vBulletin Message
Hi everyone.
On the machine of one of my customers (Xerox WC7845i) I found the breakage of the fusion film, after replacing the FUSER with one of the same code removed from a functioning donor machine, the problem did not disappear.
Now the machine releases the code 310.380.000 P/Roll Latch motor fail.
I didn't find the specific error on the net but others (like 310.330.00) that indicate a fault in the fuser motor.
Some of you have already had this error code, can you give me a hint on how to fix it.
I have a donor machine and I will try to change the fuser motor, I hope to solve, but the hope is unprofessional as we all know ...
Excuse my english, I'm using google translate
Thanks everyone for the help
Hi everyone.
