Fault Code 310-380: P/Roll Latch Motor Fault
  • servizionsite
    • Dec 2022
    • 5
    [Error Code] Fault Code 310-380: P/Roll Latch Motor Fault
    vBulletin Message
    Hi everyone.
    On the machine of one of my customers (Xerox WC7845i) I found the breakage of the fusion film, after replacing the FUSER with one of the same code removed from a functioning donor machine, the problem did not disappear.
    Now the machine releases the code 310.380.000 P/Roll Latch motor fail.
    I didn't find the specific error on the net but others (like 310.330.00) that indicate a fault in the fuser motor.
    Some of you have already had this error code, can you give me a hint on how to fix it.
    I have a donor machine and I will try to change the fuser motor, I hope to solve, but the hope is unprofessional as we all know ...
    Excuse my english, I'm using google translate
    Thanks everyone for the help
  • adriansto
    • 2369
    Re: Fault Code 310-380: P/Roll Latch Motor Fault
    Originally posted by servizionsite
    vBulletin Message
    Hi everyone.
    Problem with P/R latch motor. Check motor, motor cables and connections, PJ 524 on electronic board.
    • servizionsite
      • Dec 2022
      • 5
      thanks for the information.
      I guessed whether it was the motor or the gear pack.
      Fortunately I acquired a functioning donor and recovered what is needed.
      You have been invaluable, thank you!
