dcc400 imari color alignment run
  • copytech200X
    • 264
    Hi All,
    i having color alignment problem..i had replaced mob sensor assy,ess and mcu pwb and initialize all (iit,sys user ,stem and iot) but results NG. all parts taken fr working machine...
  • pepperbrick
    • Mar 2009
    • 17
    try replacing the ROS assy.
    • TechMate
      • Mar 2008
      • 285
      Originally posted by copytech200X
      Hi All,
      If you have PWS diag tool, use regicon to do alignment. another alternative is that every machine has an nvm settings list usually hidden in tray 1 (side pocket). Enter into service mode and NVM r/w the values. You don't have to replace any component as this is just an electronic adjustment
      • copytech200X
        • 264
        customer place flooded so their do cleanin' machine by themselves and throw the tray 1 nvm settings lists ...
        anyway i try replace ros ASSy ..update ur guys soon..
        • ck1
          • 485
          imari Dcc400 error code
          my imari Dcc400 come the code '102-372' .Why happen and any solution ? help thanks
          • johnner66
            • Mar 2009
            • 265
            try replace the option ps 3.5 voltage n 5vdc ps i change it work fine for the 102-372
            • TechMate
              • Mar 2008
              • 285
              Remove the HDD and restart the machine. If no fault, then change HDD. But if you replace the HDD and fault still comes up, then the real faulty component is the interface PWB PL9.1 item 6 pn101K37783.
