This method works if the donor machine was at the same software level as the machine you want to to put it into operation.
If not, then you must use special altboot software with original files.
Altalink 80XX Series special Altboot method
What mean rewrite sd card and hdd? Did you format the hdd? Did you used original files for C8030 or files copied from another machine?Leave a comment:
i have a problem with xerox altalink 8030 , after rewrite on SD CARD and HDD , i made a altboot usb with FORCE_UPGRADE and swup_usb but the screen stays blue and after a sec it makes a beep sound and then restart
Ho we can put the both files in flash usb is inside the EFI folder ?Leave a comment:
Swup files at root. Try to reimage sd card, format hdd, and altboot machineLeave a comment:
Good morning, we try yesterday bot ways to update , ALTBOOT normal like you comment and LTBOOT (picture)
I think that something works because now the message are in English(before was in French) but still without initiate the machine and working.
any other Idea??
Thanks for your timeLeave a comment:
Hello,
I have a xerox wc6655i but asks for service plan.
Is there anyone who can help me with activation software
I dont know what it can be. The service manual say the next step is to replace SBC pwb. I think one of the electronic boards have problem. Sometime IIT pwb make trouble. Download the service manual from net try to enter service mode if you can and search for machine errorLeave a comment:
Too many files there. On altboot folder you must have software dlm file = 464MB , FORCED_UPGRADE and DISABLE_DATA_BACKUP.
Nothing else on altboot folder, noting on root of the usb stick. Try also usb port on the rear of the machine if the front one do not works.
If this forced upgrade procedure do not works then the two swup file on the root of the usb stick and on altboot folder the files from forced upgrade.
this mean special procedure.ltboot.
any other Idea??
Also, I'm trying to update the firmware but doesnt work, attaching pictures:
WhatsApp Image 2025-02-11 at 12.29.01(1).jpgLeave a comment:
Try to replace the 2 pieces dimm memory then the manual says to reload software and if that not works must replace the motherboard electronic board.
